Hi,
I'm planning on making dynfi accessible through our reverse proxy (which supports strong authentication). Unfortunately this means that dynfi cannot run in the / (root) context using absolute paths.
I would need something like this:
https://reverseproxy.com/dynfi/ <----> http://internaldynfisrc.local:9090/dynfi/
Is there a way to change the context of dynfi?
Thanks
DynFi behind reverse proxy
Re: DynFi behind reverse proxy
Hi Frank
Not sure if I understand the "change the context of dynfi".
DynFi Manager runs in the root context, just using the IP address and port specified in the configuration. (https://dynfi.com/documentation/configu ... #ipandport)
Then you can reverse proxy the way you wish. E.g. for nginx this could be something similar (not precise code for "copy'n'paste" though):
This way you should be able to run DFM in "the root context". At lest it works for me this way
Best
server {
#ports and certificates here
server_name reverseproxy.com;
location /config.js {
proxy_pass http://ipOfDFMHere:9090;
sub_filter 'http://ipOfDFMHere:9090' 'https://$server_name';
sub_filter_types "*";
location / {
# other proxy stuff
Best
